Premium members don't see ads.Click hereto upgrade.
How are you recording while driving???
Minnesota RC
Minneapolis MN
I have two action cameras that cost $30 each. I made two aluminum brackets, 1" square tube, and some spacers to mount it to each truck.
The 1" square tubing about the length of the camera which is bolted to the base (which is bolted to the roll cage, either bolted to the cage itself or using two strips to secure the base). Then the camera sits on the square tubing, and a bolt goes through the channel and screws in tight.
I also have a FPV on my losi 5T, which is okay, but due to electrical interference from the spark plug, the video is somewhat grainy.
Phill2
Yeppoon QLD Aus
Yeah you got the professional grade👍🏽
That's the one P3Pro
I use Litchi cause it's got a few features DJI GO hasn't.
Any of your vids on You Tube?
I'd be interested in seeing them.
Just found em - all good (y)
crucialRC
Maryland, USA
Looked at getting a mavic pro$$$ about $2500 here🙄 rather have another 1/5
Why so expensive? It's coming from China so I would think it would be closer to you🤔
Yeah I have a few videos with it. I don't hardly spend enough time with it. My RCs take up too much time.😥
Phill2
Yeppoon QLD Aus
Mavics are about the same here in Oz.
Dick Smith has refurbs that aren't too badly priced.
If I buy another drone it will be a refurb.
[/QUOTE]
I know that feeling only too well.
It seems every time I charge a battery it blows a gale for the next week.
Seandonato73
Arw they really that picky with wind? Never had a drone. My bigger helis can stand up to some fairly stiff winds.
Phill2
Yeppoon QLD Aus
They'll take a bit.
It may just be me but I don't fly if it's above 30kph on the ground cause it's going to be a lot more up higher..
It's a lot of money to get blown away.
AnubisBC
Portland, Oregon
That reminds me of a friend who was testing out waypoints on his programmable drone. Instead of manually controlling it, he was using his laptop. He set it to go home if it hit a certain wind speed, but rather than programming his lat. and long. he trusted his uncalibrated (cheap) GPS. Wind picked up and it tried to go home and missed its mark by 200 yards. He had to go slogging through a culvert to find it!
siblues
Central New Jersey
You can always have a nice gimbal set up on the multirotor like a Storm32 or any decent controller and they can follow a specific target if set up to do so.It can pretty much stay stationary maybe ten feet off the ground in the center of where you are driving and the gimbal and some minor movement from the multirotor will handle the rest.
Pixhawks,Apm's and many others can do the waypoints and tons of other crap.I haven't kept up but they should be even more advanced now.
Phill2
Yeppoon QLD Aus
Litchi will do that but I want to follow the car as well.
You can't trust em even with the controller in your hand.
They don't often have problems but the potential is always there.
siblues
Central New Jersey
I think in order to stay close to the ground and have enough speed to keep up maybe an octocopter like a Tarot type would be better bigger motors and they have huge 15-16 inch props.That should do the trick.I don't have any experience with DJI stuff but I know they make really good stuff right out of the box.
