jeez thats i think a pretty obvious porblem right there, expensive lesson learnt? what are you running now?@Ollie I did not, I had the tr air box on 2 seperate 2.0's and both engines died from dust ingestion and I wasn't taking a 3rd chance.
solid and simple setupDdm velocity stack with a dt-1 triple foam filter.
That is what I run and is perfectly fine.Ddm velocity stack with a dt-1 triple foam filter.
Thought i would chime in, in regards to the TR airbox. The Taylor intake is a very good option. Very light, gets the filter up in the cold air away from the cage, and doesn't restrict air flow in any way. The TR box is shite, it's heavy, and places stress on the carby and manifold, there's so much weight hanging off the carby. Still haven't worked out why people run it tbh
https://www.taylorrc.co.uk/product-page/rcmax-billet-clamp-on-intake
Taylor intake doesn’t require any trimming or cutting.personally would say the only reason people run it is because it relocates the filter into a pretty damn good place and requires no cutting of the cage compared to the crazy stu intake
Little peak at the remodel for road course just 1 pic for now until I get the ball rolling View attachment 84793
Lookin good!Here it is ready to go. It's lowered in the rear using front shocks and some other odds and ends for the road. It doesn't bottom out at all and i took a corner into the cul-de-sac at maybe 35-40 and it just hooked and didn't spin out. To boot it still has the center and rear lockers but ill be switching them out as if you get back on the throttle hard it does start to slide but i expected that just wanted a base line.View attachment 84855
