Thats the right approachI have a very bad habit of being super critical of the things I do. I have an expectation and if it doesn't meet it ill keep hunting till I get it right
Anodizing thisNo reason to hide anything with this as I wanted this thread to be educational and open to critique... this time I tried type 3 anodizing which is a hard coating. Granted I don't have nor feel safe to ramp it up to the required voltage I tried with what I have and the process focuses more on voltage rather than amperage with type 2. You can see the color difference between the parts. The darker parts is my limitation for type 3 and the bath was kept at 50 degrees Fahrenheit. The lighter purple by the coil is type 2 also with the wrong way to dye the parts. I had stumbled upon the right way I believe to dye and its not heated to 120 degrees Fahrenheit but yet its left at room temperature and the dying process takes about a minute ..
can doug make this thread a sticky though,Thank you PaulI want it to be a source of good information for anyone here that wants to give it a go
