buzzkill
Mad?scientist
- SLO California
What do you guys think about using a ESP Ported top end in this setup ? this has my attention LOL and Im not gonna do my own porting so
Not completely true. Intake timing is a bit better on reedcases because its not cutoff by the piston so you can get your maximum case fillrate also there is no air blowback because its cutoff by the reedsystem. It makes more rpm and torque however torque is USUALLY lower on reedcases because the greatest benefit is usually RPM.It will need added reed porting I would think, because you only reep the benefits of a reed with special reed porting.
Oh absolutely windowed pistons are a must. It just makes sense when more of the air and fuel makes its way easier to the topend then you get more power.With reed cases would you do windows in the pistons?
You can gain 20 to 40% more power its significant and the reason for it is if you think of it this way. Each port makes it less difficult for the piston to push the air from the case to the top end "there is a bit more to it then that but that's the big one". Windowed pistons that align with the ports essentially do the same thing. Make it less hard for fuel and air to reach the top end while allowing more of it and it does a better job of expelling exhaust. You need to be careful though because this changes the resistance of the engine. Having a higher exhaust port can gain you more rpms but you loose torque which is OK in these cases. Im more of a fan of split exhaust ports for wider and taller exhaust timing however thats very difficult to do.This thread makes me wish I went reed over that red arrow... so how much benefit with the reed case are you losing when you put a piston port top end on it?
Send it to me I'll put it on the DYNO ! I got a chassis lolNot completely true. Intake timing is a bit better on reedcases because its not cutoff by the piston so you can get your maximum case fillrate also there is no air blowback because its cutoff by the reedsystem. It makes more rpm and torque however torque is USUALLY lower on reedcases because the greatest benefit is usually RPM.
This is why I used such a thin copper gasket for a tiny squishband. I know I won't be able to get the RPMs I want without a 5th port so I want to gain torque. More ports = more fuel and air and less piston ring friction.
Funny thing is while developing my 50cc reedcase I learned a quite bit about flowdynamics in the lower case that most people theorize about and most of it isn't true. Once you add a reed system that isn't restricted by let's say "an air leak" you will fill your topend more reliably. This is why most motorcycle and atv engines work this way just slightly different because the power is significant over piston intake which is only a thing because of money saving. The limits of 4 ports haven't been reached and I think my running video will be proof of that. TBH I'd like to loan this motor out to a youtuber if they find it interesting because I don't have a donor car to put it in right now and have decided that I don't want to strip my already built baja.
I know ESP sells window ported pistons on DDMI went and did some looking on obr's website and im not sure if their pics are generic but their replacement piston for a full mod g320/g340 looks stock. Anyone with an obr reedcase here know if they did windows on their pistons?
OBR does on certain series of engines. Full mod means head, piston, and crankcase is not stock but to what extent do they modify pistons is the question. Just shoot em an email.I went and did some looking on obr's website and im not sure if their pics are generic but their replacement piston for a full mod g320/g340 looks stock. Anyone with an obr reedcase here know if they did windows on their pistons?
Don't tell me that. I got an SS and it better have windowed pistons for what I paid for it. Then again the engine does sound really good.I helped a mate rebuild his 32 obr reed and it was a stock piston??
Well if I ever get a dyno ill do it. I got a quote on my CNC and if I decide to buy it its gonna take 30 months to build.it would be interesting to Dyno this motor in stages , Reed no porting / porting/ window piston etc. !
Yeah they are made to order. Unfortunately C-19 is also delaying this further.30 months for them to build the cnc?
30K for a brand new one that has 0 hours on it. 28K for a used one with 5000 hours on it. Its a no brainer. I'll just be renting some CNC time for development. Perhaps I'll try a metal 3d print.Why not buy a used one? Cheaper and already built. Seems stupid to buy a new one to me ?
well this is a DIY low cost DYNO so ???? or send me the motor , BTW WHY would a 30k$ mill used be $28k ??? WTHWell if I ever get a dyno ill do it. I got a quote on my CNC and if I decide to buy it its gonna take 30 months to build.
