- Reaction score
- 22,962
No way to tell if you don't run it mate.
Yep gonna keep an eye on that baja roller on kingmotorrc.com im itching to get it going however I really don't wanna tear my OBR out of my Baja.No way to tell if you don't run it mate.
also keep an eye out on the fb groups and ebay , some cheap rollers come up time to timeYep gonna keep an eye on that baja roller on kingmotorrc.com im itching to get it going however I really don't wanna tear my OBR out of my Baja
Yeah true however I CAN tell there is more torque. Basing this off the pure rumble of the engine. It just wants to shake violently in a good way. ?. TBH i really do "feel" like I get more RPM aswell. I've been back and fourth with this engine all week and you notice the pitch change during throttle when you have done it as many times as I have. However guess we'll never truly know.the only way to really tell what is happening is to dyno the motor in between changes , other wise you are just guessing.
get a low cost RPM meter off Amazon $15 , uses a hall effect sensor ( magnetic ) so just alighn it with the flywheel magnet and BAM you know what your Rpm's are. you will need a wall wart power supply for it BTW .Yeah true however I CAN tell there is more torque. Basing this off the pure rumble of the engine. It just wants to shake violently in a good way. ?. TBH i really do "feel" like I get more RPM aswell. I've been back and fourth with this engine all week and you notice the pitch change during throttle when you have done it as many times as I have. However guess we'll never truly know.
I'll definitely invest in one if I decide to start selling engines. I need one for doing the lort timings on the 50cc project anyway. We can start to see if certain porting merits any positive changes.u need a rev tach-omiter to see ur increases ?....i bought one....3-4 years ago n its still not fitted.....![]()
doenst even need all that, just buy the trailtech tachometer , goes on your spark plug wire and measures rpms. not too pricey eitherget a low cost RPM meter off Amazon $15 , uses a hall effect sensor ( magnetic ) so just alighn it with the flywheel magnet and BAM you know what your Rpm's are. you will need a wall wart power supply for it BTW .
https://www.amazon.com/DIGITEN-Digital-Tachometer-Proximity-Switch/dp/B01FQMI18Y/ref=sr_1_6?crid=1CFBF8BGC5IP6&dchild=1&keywords=digital+tachometer+hall+effect&qid=1609787678&sprefix=tachometer+digital+hall,aps,265&sr=8-6
just take a pinion gear drill/tap 2 holes , match those holes on the bar screw it together SIMPLE and cheap, I installed a RPM hall sensor in this cover and it works great using my software etc. the graph is the rpmsThinking this might be a safe alternative https://www.ebay.com/i/362676720228...75ecGLNwkJK3FpcUAQJIyxMI6Y8He9ocaAnHnEALw_wcB
However that one wouldn't fit my engine. Has already a hex size. Probably could fit weight to it.
same thing , BUT you need 8vdc MIN. so for a RC you need a boost regulator or power supply batteries or ?? AND does it go up to 20,000 RPM ??doenst even need all that, just buy the trailtech tachometer , goes on your spark plug wire and measures rpms. not too pricey either
it goes on the plug wire@Z.hb71 I'm pretty sure the eyelet for the spark plug is to measure temp
yes it does go up there.just take a pinion gear drill/tap 2 holes , match those holes on the bar screw it together SIMPLE and cheap, I installed a RPM hall sensor in this cover and it works great using my software etc. the graph is the rpms
This cover can be used on most motors BTW
they do, people are getting 16-17000 rpm on bigbores under load, a smaller 34cc should be even more. idk why his is reading so damn lowThought these engines had more then 10k rpm to give?![]()
that is my motor in the baja Idle is about 5k or so , got a 6k spring in the clutch , Im just revving it on the ground its not attached to my DYNO so I cant run it wide open, lol ! .Thought these engines had more then 10k rpm to give?
Did you even see idle on the graph? Stock idle should be at 2000 as per zenoah 3000 seems a little high to start the run? And yes I see your running a clone engine but should have similar traits, also couldn't you use the magnets on the flywheel? Or do you need a seperate one
yep?wht i got top rightdoenst even need all that, just buy the trailtech tachometer , goes on your spark plug wire and measures rpms. not too pricey either
just what that thing likes to not die at idle ! also because off the line is WAY better with higher idle , it tended to hesitate at lower idle.5k idle...dafaq ?
