Decent, they unglue easily thoughhow are the stock 5ive b tires for bashing???
I run jconcept chasers and I think they run great. Some guys like the madmax mini pins but I’m not entirely sure I trust their opinion.
No I recommend avoiding the track in those conditions. I won’t be running in that anymoreShould I be looking for a set of tires for wet conditions too? I'm remembering back to your mudded up photo's and thinking maybe I should have a knobby set as well? All I have now are trenchers.
Although I don't think they are the best for the track, i really like my trenchers. I've found them to be long lasting, have the right amount of grip and slip for general mixed use. They do decent on pavement, and excellent on grass surfaces. Just due to available I most likely wont be running them after this set. If you don't have anything else till your first race I'd give them a go. At least then you know how they react once you get another set.Should I be looking for a set of tires for wet conditions too? I'm remembering back to your mudded up photo's and thinking maybe I should have a knobby set as well? All I have now are trenchers.
I honestly couldn't tell ya but I lean towards HPI as everything else is HPI, except the upgrades that is. You could be right and I did consider the previous owner may have changed some things. Came with a original hpi tx so I assume everything is hpi. The internals seem to fit ok.is your transmission internals rovan? if so that would explain the gear. rovans trans internals are always off, the diff cases are wider, layshafts are longer (i had booth and compared the rovan was .5mm longer) so i wouldn't be surprised if the gears were off. and i think the 4 bushings was a good move![]()
Un-glue? I've never glued a set of tires for my BAJA. You don't need to glue the tires and rims because the rims have bead locks .Decent, they unglue easily though
someone asked about the 5ive b tiresUn-glue? I've never glued a set of tires for my BAJA. You don't need to glue the tires and rims because the rims have bead locks .
wht was wrong then?
You're in the HPI section . When I see 5IVE or 5B i think HPI not those stupid Losi wheels.someone asked about the 5ive b tires
You're in the HPI section . When I see 5IVE or 5B i think HPI not those stupid Losi wheels.![]()
