MonsterAir
Lone Racer 🤠
- Long Island NY
- Thread starter
- #161
Looks like you had some fun.
18/56 seems to be the sweet spot for rigs under 32cc. Although, for you since your racing, that depends on the track . So I'd give em all a try ?Figure I'd give an update. Disassembled and cleaned everything piece by piece. Took 2 days! I swapped out the cheezy KM rear arms for Integy and getting as much negative camber as I want without the lumpy feel in the layshaft. Reason I went with Integy was because they were the only option I knew of that has reversed threads on the turnbuckle. Much easier to play around with suspension this way.
I had it out for a tune and she's running well just have to remember to lock tight that layshaft bolt, kept backing out on me. The Olimat pipe really sounds feking awesome. Very happy with that even though I hate the header design but thanks to Z for recommending the MOD kit I don't have to be annoyed by it any longer. Will do a video when the weather get's nicer and I have some better gearing for it. Right now running 17/57, debating on whether to go 16/58 or 18/56 next.
19/55 is not bad either... specially when you don’t have good grip
32cc is very torquie
