cbaker65
Well Known Member
- Reaction score
- 4,599
Or because I've been hanging with you degenerates for too long ?????j/k
Doug may have to make another special vid for you!....
Doug may have to make another special vid for you!....![]()
It really doesn't Z, not even a little bit.Oi ? off it looks cool ??
He is in such deep cover ( tinfoil hat on?)
That if I ban him it will give the black hwak? a gap too nap ol mike??? send him for more ?? probbing? fear that will be the last we hear of him??
Well, your opinion means absolutely nothing, considering you probably think that mtxl looks good ??It really doesn't Z, not even a little bit.
Oi you signed up for the mod job so suck it ?FFS guess ill have to fix this againnnnnnn!!!???
+1I would start w tightening all the bolts. Manifold, carb, head.
What insulation?You sure that you didnt over heat it with all that extra insulation?.......![]()
Pullstart is open and bottom of the case is not blocked. And he plenty of holes on the front of the cage for air flow. So problem not.Your little rats nest!....![]()
Was doing it last run too
Spark is fine. Wouldn't stay running if it was feked. And it's a brand new plug with 1 run/1/2 hour on it.Have you checked your spark plug?
Some times with high compression & heat ,the end of the spark plug will close off!
Yep we will see , hope so ????I'm right ? I know it
