Some ? ought to work eh ???
Know it would on me ????
The hot dog is an up sale and wouldnt work.....make ???? kissy facesfor y gal ?? foot massage .....make dinner for a week hell though in a bitta ??? too sweeten the deal?? coz it sound like you gonna quit on us?????
We are all cheering for you??
give some pipe? my bad ?? get the pipe??
That engine don't sound to happy and I took to long to start, almost like it has an air leak ?
Ok ,It definitly does not start with a drill too good ,that was the problem all this time ,BAD BAD BAD idea ,as I stripped the nut threads ,
thank God that it was the nut ,so I had some extra fly nuts ,an quit the drill ,an was able to fix my starter by using parts from a weed wacker!
Yeah, I definitely don't recommend using a drill without the correct parts. I spun the flywheel nut off using that method. Lucky for me it didn't strip anything.
Running pretty good now though!
Yeah drill start via a flywheel nut is no good, we all know how that went for me ????
What starter did you buy? China/eBay/rovan/km poop?Fekin starter broke ,going to have to find something better ,seen a metal one ,would have got it ,but did not see any
in the US ,fek ,the paw just snapped ,the engine feels like it has a lot of compression ,too much for these cheap plastic
starters!....
The engine was running ,then hit & miss wanting to cut out ,as I was trying to start it before the starter broke ,I had noticed
that there was feking sparking from the plug wire insulator to the head ,so now I know why it was cutting out....then messed
with it an went to start it ,that is when starter broke ,so now I need to buy another better starter!...
Get a cy pullstart. They last with high compression obr engines so it will do fine on that motor.
What's the "spark plug coil insulator" ? Do you mean plug boot ? If so, some people buy the msd wire and boot off ddm, I can't speak on it, as I've never had one. My stock cy/zen one worked fine for me ?What about a spark plug coil insulator ,I had notice that people has changed those out?
The upside out of this ,is I managed to spot the arching ,probably my damn issue all this time!....
