KM Baja.
cbaker65
Chokin the chicken too much! πŸ”πŸ˜³
PLUS member
That engine don't sound to happy and I took to long to start, almost like it has an air leak πŸ€”
I was thinking the same ,an was thinking on pulling the carb back off to check the isolator ,it was on there new but still ,
I had gotten new engines before with loose stuff on them an I did not check to see if it was tight before I put the carb on!
cbaker65
PLUS member
Ok ,It definitly does not start with a drill too good ,that was the problem all this time ,BAD BAD BAD idea ,as I stripped the nut threads ,
thank God that it was the nut ,so I had some extra fly nuts ,an quit the drill ,an was able to fix my starter by using parts from a weed wacker!
I went to try it out an the first pull it fired up ,it shocked me ,so I left it idle an ran in the house an grabbed the Go-pro an was still
idling when I came out ,this is how it runs now ,I will put the wheels on an try to run it!....:cool:
AnubisBC
The Professor πŸ‘¨β€πŸ«
Build Thread Contributor
Portland, Oregon
Yeah, I definitely don't recommend using a drill without the correct parts. I spun the flywheel nut off using that method. Lucky for me it didn't strip anything.
Running pretty good now though!
cbaker65
PLUS member
Yeah drill start via a flywheel nut is no good, we all know how that went for me πŸ€¦β€β™‚οΈπŸ€£πŸ€£πŸ˜¬
I did not have issues with it on the old engine ,but I think do to the bigger size engine ,I guess something
had changed in how far the flywheel sets in for the starter paw ,the starter would get stuck an not retract ,
I changed the paw out from a shindaiwa starter ,it was a little bit more shorter in height the the other an didnt
throw out as far making it hang up!
It was throwing me for a loop because there was not nothing physicaley wrong with it an worked like it should off
the engine!
cbaker65
PLUS member
Fekin starter broke ,going to have to find something better ,seen a metal one ,would have got it ,but did not see any
in the US ,fek ,the paw just snapped ,the engine feels like it has a lot of compression ,too much for these cheap plastic
starters!....:banghead:
The engine was running ,then hit & miss wanting to cut out ,as I was trying to start it before the starter broke ,I had noticed
that there was feking sparking from the plug wire insulator to the head ,so now I know why it was cutting out....then messed
with it an went to start it ,that is when starter broke ,so now I need to buy another better starter!...:banghead:
Z.hb71
Well used πŸ“ Harvester😳
What starter did you buy? China/eBay/rovan/km shit?
Get a cy pullstart. They last with high compression obr engines so it will do fine on that motor.
cbaker65
PLUS member
What about a spark plug coil insulator ,I had notice that people has changed those out?
The upside out of this ,is I managed to spot the arching ,probably my damn issue all this time!....:cool:
Z.hb71
What's the "spark plug coil insulator" ? Do you mean plug boot ? If so, some people buy the msd wire and boot off ddm, I can't speak on it, as I've never had one. My stock cy/zen one worked fine for me πŸ‘
cbaker65
PLUS member
Yea ,the boot ,it needs to be replaced!...At one point ,I am happy that I found the issue ,but pissed off about the starter ,it is the
cheap :poop:
Rovan stuff!....:rolleyes:
