szaki75
to avoid a narrowing squish opening and trap gas in the squishband. for me ideal would be a concentric squish cut with the piston dome, but to make the suitable tool looks to be a problem.For what purpose?
as for compression, we are on the same page
it is one way to accommodate the +2mm stroker crank, but it changes the port timing (and duration) drastically. raising the cylinder by 1mm means 6-8deg change in the port durations.I've read you can make up the +1mm with a gasket ...not sure where you would find one without stacking them
a more elegant way is when you cut the 1mm out from the squishband. (it won’t disturb the timing since the relative position of the ports to the stroke won’t change)
