Look sexy as fuk
I thought about it, would look good too. Shoe goo would probably do the trick.You can run some stainless mesh in the window for that desert racer look.... keep thinking about it for my 5ive t.
Your one to talkClean up the pipe
Your one to talk
It should clean up pretty easy with scotch brite.OKAY I GET IT
But seriously it ruins the look of the rig
I say do it. Get the rcmax one . I keep breaking them so it's a good way to go . You'll transfer the damage to the shcok tower but it's much easier to find a plastic shock tower then it is to find a stock front bulkhead.What is the general opinion of an aluminum front bulkhead? Mainly how much strength does it add to the front end?
Ordered the Rcmax 1piece aluminum and the brace that goes with it.I say do it. Get the rcmax one . I keep breaking them so it's a good way to go . You'll transfer the damage to the shcok tower but it's much easier to find a plastic shock tower then it is to find a stock front bulkhead.
Rear bulkhead is fine in plastic.What about the rear bulk head(s). Installing the RPM arms and the rear bulkhead(s) seem to be pretty stout and positioned as such to limit possible damage.
