- Crafers South Australia
If you can swing the tr ....go for it
The regular or HD version?If you can swing the tr ....go for it
Either, both are great.The regular or HD version?
Good servo, use it on my bajaWent with the HD version. Think I have everything covered now, just need to wait for delivery and it will be up and running.
While I was hooking up the radio the throttle servo went out. The servo was a Savox sc-0251mg. Worth a poop or junk? Too late now because I ordered another one. They look like pretty nice pieces and not made in China.
Old shocks, idk if the seals are good or if they will leak. One pissed the oil right out and needed new seals. Better than wasting good oil.I see you like to lull people into a false sense security. You trick us into thinking you’ve got some brains, then at the last minute pull the carpet from under our feet.
You might as well shout Ta Da……I’m an idiot.
Basically you couldn’t wait one day and spend $5 on some proper silicone oil.
My personal favourite is the Golden Horizon sets. It’s a mixture of both plastic and metal, but not having those I’d go for the Red Arrows. Bare in mind that you will move the weak spot to somewhere probably more expensive.
On mine I still run plastic bulkheads so that would be the weak spotLike you found out Doug, strengthening one moves the weak spot somewhere else. Look at your donks.
