Hpi 5sc refresh
brokestroke
You can run some stainless mesh in the window for that desert racer look.... keep thinking about it for my 5ive t.
I thought about it, would look good too. Shoe goo would probably do the trick.
Degreased the entire thing today. New fuel lines, and front bumper brace. Pulled the diff and installed new pins in the shafts and rotated to the next slot in the FLM cups. Threw some fresh grease in while I was at it. Found out the battery pack was completely toast so got a new one on order. Ordered a few more bits including the rubber washer/pin retainers for the body clips and some shock parts. Reinstalled the front and rear sway bars to see if I like them or not. The last bit was resetting the tires on the beadlocks. The lock rings are beat up pretty bad but should work just fine.
brokestroke
Well the lower control arms were pretty scraped up and the shock threads are stripping out on the rear arms. Decided to go ahead and order a full set of RPM upper and lower arms. Figure they will be a worthy upgrade to compliment the other parts it already has.
brokestroke
What is the general opinion of an aluminum front bulkhead? Mainly how much strength does it add to the front end?
I say do it. Get the rcmax one . I keep breaking them so it's a good way to go . You'll transfer the damage to the shcok tower but it's much easier to find a plastic shock tower then it is to find a stock front bulkhead.
brokestroke
What about the rear bulk head(s). Installing the RPM arms and the rear bulkhead(s) seem to be pretty stout and positioned as such to limit possible damage.
