Facebook groups make me laugh
You can put a slight finish on it without an issue assuming the cylinder is round or setup in torque plates. BUT the issues is you may be ruining the finish on it as it was designed. It is amazing how much the grit and the way you finish it will effect both power and longevity. So some people may not realize they think they are doing good but in the end are actually hurting themselves.
I'm just speaking in terms of trying to get more time out of the engine. I don't expect a honed cylinder that isn't replated to last 2 seasons.
Already has a new engine. I'll have a local racer look at it once the track reopens. And the other has the obr 34 full mod. I just think its funny that these MASTER builders all talk this big game but then say not for hire...
Diesel doesn't have plugs its compression ignited. The glow plugs/ intake heaters are just there to help warm the air up to make starting easier.
Tell the idiot to start it and take the plug wire off if hes so smart. No plug= no fire in the hole= engine stops running.
Yep it's called dieseiling, or after run. Typically means there is a hot spot in the combustion chamber allowing the fuel mix to be ignited, this can also mean there is extensive carbon build up in the chamber as well. I doubt most of our engines get enough use where it would be a major concern.
