- Crafers South Australia
But this means jack here as we don't run 1/1?? so how dose this help the OP???But they also use a break in oil . Compared to what they would normally use.
Cleaning his basement ??Aight where's @Seandonato73 ppl are getting fired up right on schedule lol
I think that's an outbuilding...he could have a basement dungeon in the outbuilding thoughCleaning his basement ??
Lmao! 40:1 for everything!!Not breaking in a 2stroke????
Well IMHO, I think your HO is a bigger crock of !
Sorry at a wedding.... just got home.
So the very short version, break in is a waste of time. Idc what engine. Dynoed too many to justify pussy footing around getting a load on the rings. Free revving is also bs, rings need dynamic load to force them out into the cylinder walls. Normally you would vary the rpm a bit, but full load only occurs at rated rpm. don't matter if that's 1800 rpm or 20k rpm. (Our engines are typically rated to around 15k for peak power btw + or - a bit) synthetic does take longer to break in. It's just a fact. It lubricates better than dino juice. I don't swap from one to the other, its normally not worth the extra bottle. The ring (s) should be set within the first few minuets of running. The heat cycle is poop for the birds, and well as low rpm break ins. That's to bed journal bearings, and 2 strokes use ball bearings. So for the sake of argument, worthless to consider for our specific application. The engine should be allowed to warm up a bit before getting with it. After that balls to the walls.
Oil ratio in modern engines is largely in part because of emissions. 32 to 1 was the standard ratio for years. Yes more oil helps seal the rings an cool the engine....but get this, more oil decreases the octane rating, and will cause more carbon fouling of the engine. Oil ratio is also determined by load, and rpm. 2 strokes use a pass through lubrication system (hence why we add oil) so the more rpm, the less time the oil spends in the engine, so you would need more oil. You also have to factor time loaded. In a race application I would spring for a higher oil rate, as the load on the engine is typically larger than a basher. You can tell this from your spark plug. (Which we recently talked about) funny thing is, a 250cc heavily modified mx engine get 40 to 1 nowadays and lives a good long life. And we use 25, and 28 to 1 in our glorified weedwacker engines. We mentioned saws... I have saws that range in age from the 60s to models currently in production. The all eat the 40 to 1 I feed them and none of them have given up the ghost, due to an oil related failure. I guarantee I run my saws harder cutting, in much worse conditions than an rc engine will see in its life.
I'll echo what polar, and a few others have said. Run wtf you want. If it works for you, no use squabbling about it. I'll stick to 40 to 1, and obr and whoever else will tell you thats not enough oil, because they can. And for obvious liability issues as well. Imo anything over 32 to 1 is a waste of expensive oil. Just me, idc how much you put in your engine.
Oh, my basement is my shop.... no Zed dungeons for me, or out buildings atm.... one day...
+1 ??I encourage everyone to make up their own dam mind.... I'm just an idiot, ask my wife ?.
