Thank God your not putting that trash on the hammer
thanks ryan ,Looking good Paul
thanks doug ,Great work spent now slap that female dog on there
ryan,
There are a lot of carb numbers that Interchange. If you look at the break down of each carb you'll see the bore and venturi are the same, but they changed this or that and gave it a different number. Could be as simple as no purge assembly, or the metering spring is specific for a certain mfg. They all basically run the same in the end.
sean ,There are a lot of carb numbers that Interchange. If you look at the break down of each carb you'll see the bore and venturi are the same, but they changed this or that and gave it a different number. Could be as simple as no purge assembly, or the metering spring is specific for a certain mfg. They all basically run the same in the end.
thanks lanceI like this spents
i bet there off the twin doug and they'll be the same as mine, the 997'sI have a pair of "686" but dose not say that on the carb ill dig them up later and get the number
