- Thread starter
- #561
The gear mesh looked fine so I don't think so ,but I will check ? if so, bonehead incoming ??Chassis not bent is it?
It's not melting, the teath just break off, maybe heat makes em brittle after a few hours? No idea.Someone explain this to me. How do the Spur gears strip like this? If the gear mesh is good that really shouldn't happen . Is the pinion gear getting hot and melting the spur gear ?
I've seen pictures like Z's before and never understood how this happens.
Could be just not made for upgraded engines. Maybe it was intended for a upgrade from stock for a stock engine ?
also noticed, the hostile axle boots are absolutely feked ? waste of 14 bucks, pieces of poop ???
