Yes but.... dude I was never this bad. And I definitely learned my lease on with thatWasn't so long ago budskating on thin ice
Oh he didn’t paint it brown?And get lock jaw from all the rusty steel on the pos, no thanks.
Its a matter of opinionYes but.... dude I was never this bad. And I definitely learned my lease on with that
Oh he didn’t paint it brown?![]()
I bought a Bart... he bought a pipe... literally
I wouldn’t have a hard time believing that he found that on the sidewalk
Is it a steel pipe or aluminum?I mean like I remember when I was reluctant to buy a pipe. But at least I bought a cheap one. Then couldn’t stand it and bought a Bart. This should work for you. I can’t bear to see that... do you need it? (The cheap one I bought) I mean it’s not good, but...I can’t see that monstrosity on ur build
Too slow to break much but I'm guessing the second.
Dude anything is better than that pipe on there now, but it’s prob stainless steel I thinkIs it a steel pipe or aluminum?
Whats your price?Dude anything is better than that pipe on there now, but it’s prob stainless steel I think
question mate,Yeah it does tend to see some shelf time, broken or not. Usually preoccupied with other projects. Just turbocharged this Yanmar 3tnv70 (diesel) with a GT1241Z for example.
It's a deere version of a yanmar, just wait till it blows up.question mate,
why no intercooler ?
and why's yer intake so long?
just askin![]()
Its a true Yanmar.It's a deere version of a yanmar, just wait till it blows up.
No it's a John deere yanmar, John deere had a pile of internal parts made to their specs so you can't get the majority of part through a yanmar dealer, you have to go back through deere. It's a deere engine, plane and simple. There for its a wanna be yanmar. Deere does the same thing to all their engines, its all about getting parts sales. Worked half my life for a shop that was both a deere and yanmar dealer. They don't interchange hardly anything.Its a true Yanmar.
A few reasons, boost pressure is relatively low (max is 6.5psi) and usually runs around 3psi. Therefore its not being pushed very hard causing the air to heat too much. Similar to the older 7.3 and 5.9 diesels. Also has a lack of space and air flow. To cool it would require an water to air intercooler. If EGTs stay in check without it is not really needed for the application.question mate,
just askin![]()
Its the same Yanmar that is used in the majority of the diesel Side by Side industry. Mechanical injection pump, idi industrial model. All the internals are the same for this series of motor, im sure it has a different block plate to mount to the CVT compared to other applications. Maybe slightly different mounting patterns. If it was JD only it wouldnt be branded Yanmar 3tnv70.No it's a John deere yanmar, John deere had a pile of internal parts made to their specs so you can't get the majority of part through a yanmar dealer, you have to go back through deere. It's a deere engine, plane and simple. There for its a wanna be yanmar. Deere does the same thing to all their engines, its all about getting parts sales. Worked half my life for a shop that was both a deere and yanmar dealer. They don't interchange hardly anything.
You do realize you 100% full of poop? Right? A factory 7.3l turbo diesel would run right around 13psi boot from the factory, a factory 5.9 non intercooled was around 23 psi. The intercoolers back in the day were to meat emission standards. It wasn't till later everyone jumped on the ooo it helps increase power out put as well by dropping the air temp. Problem is intercooler complicate the air system, hog room, add cost, and increase air tract volume causing the turbo to work harder for any given psi of boost produced. Typically noticed as more lag in the turbo. Up untill the early 90s there wernt many intercooled turbo engines. simply put, the right sized turbo for the power output of the engine will have better response and not generate enough heat to worry about. too little air flow, and too much fuel causes high egts. Your idea of too much air in a diesel is just flat out wrong.A few reasons, boost pressure is relatively low (max is 6.5psi) and usually runs around 3psi. Therefore its not being pushed very hard causing the air to heat too much. Similar to the older 7.3 and 5.9 diesels. Also has a lack of space and air flow. To cool it would require an water to air intercooler. If EGTs stay in check without it is not really needed for the application.
The intake is long because it is tied into the stock dual element air box. It operates in very dusty conditions so keeping the dual element was mandatory.
Idi 24.7hp stock, it is a 2018 with zero emissions. They are reliableIt’s a bad design that’s really old and dated.
Lack of air flow meaning the vehicle doesn't travel fast enough for an air-air cooler to work as it should.You do realize you 100% full of poop? Right? A factory 7.3l turbo diesel would run right around 13psi boot from the factory, a factory 5.9 non intercooled was around 23 psi. The intercoolers back in the day were to meat emission standards. It wasn't till later everyone jumped on the ooo it helps increase power out put as well by dropping the air temp. Problem is intercooler complicate the air system, hog room, add cost, and increase air tract volume causing the turbo to work harder for any given psi of boost produced. Typically noticed as more lag in the turbo. Up untill the early 90s there wernt many intercooled turbo engines. simply put, the right sized turbo for the power output of the engine will have better response and not generate enough heat to worry about. too little air flow, and too much fuel causes high egts. Your idea of too much air in a diesel is just flat out wrong.
