new bolt new isolator block and you smiling ? ?
It not only looks good, but works good too.? enjoy the ski trip⛷??Well, your opinion means absolutely nothing, considering you probably think that mtxl looks good ??
Correct but he's trying to save the aluminun obr isolator.That bolt doesn't go into the head ,it goes into a nut on the insulator don't it!
Yeah in going to torque it to spec.Woooooow. You are so lucky bud. There is enough dirt their to cost you 3 engines.
I'm thinking when you tighten the carb up this go around, don't use you wanking hand ???
Yep that's the plan. Goin to buy the same obr isolator, cuz I've had good luck ?new bolt new isolator block and you smiling ? ?
Those fins do nothing but absorb the heat, they are so close to the head and not enough air flow actually goes over those fins I think.?I wonder why that aluminum isolator works good but the rbmod isolator sucks?
Waiting on my clutch spring , tires, and exhaust coupler so the wait won't be that bad. Really want to try it out with all that extra grip and the 9500rpm take off ??
Yeas, but such a big ass manifold would absorb more heat I would think. Either way, its useless crap ??Aluminum absorbs heat ,an stays hot until the heat source is shut off ,it heats up faster an cools off faster is all!
Aluminum was primarily used for a light weight durable material!
Obr one is 25 bucks, comes with all the gaskets and a big ass carb spacer to keep the heat off. Mine worked well so I will buy again ? even in 93+ degrees at WOT all the time, zero heat soak ?
Came from ddm, so zen or cy. How long do they last usually? This time I will torque to spec. And not "good'n'tight" ?If a Zenoah I would use it. Easy to change out later on.
Not sure exactly. All depends on how well you engine is tuned. I believe they only distort when overheated or over tightened.Came from ddm, so zen or cy. How long do they last usually? This time I will torque to spec. And not "good'n'tight" ?
Cylinder and piston look fine so I hope not. Was ran like this for an hour (obviously I didn't know) so if it had the motor would already be fiddlesticked.Damn that’s a lot of dirt in the intake. Are you sure ur engine didn’t suck up any dirt ???
Ur A patient fella. I personally couldn’t deal with a rig like urs that breaks down every fuçking ride. That’s crazy!
